Starting problem on AC C
Damhoff
05-14-1999 09:49:36
after running for a while, when it is shut off it won't start back up. But let it set for about a half hour and it will start. Can anybody
help me figure out the problem?
William Powell
05-17-1999 13:06:24
 Re: starting problem on AC C in reply to Damhoff, 05-14-1999 09:49:36
Be more specific. Does it turn over when its hot? Sounds like an electical problem. Try putting an extra spark plug in one of the wires and ground it
on the block. Turn the engine over and see if there is spark. We have an 8n that started hard
when hot. Turned out to be the coil. Do you have
a distributor or a magneto? You might want to try choking it when hot and then
pull out a plug to see if its wet with gas just to
rule out a lack of fuel. Cut the problem down. Intake, compression, power, exhaust, whats not letting that happen?
