Several questions
Sean
06-04-2004 12:12:01
Hi and thanks in advance for your help. I have a 180D that is pressurizing the radiator with exhaust. When I start her up radiator fluid runs from the overflow, but slows as the tractor warms. There is no indication of water in the oil. I'm hoping it's only a bad gasket letting exhaust into the waterjacket, but am afraid it could be worse. I'm not an expert mechanic but have done some car engine tear downs so am thinking of tackling this job myself. Dumb idea?
I'm also unsure as to the exact model year. I found the following info on the engine plate: Engine Model 2800, Engine Catalog 4022414, and Serial number 2D-27297. Are there other numbers I should be looking for?
If I do this myself I'll need manuals. I see on the page I can get manuals for a 180 Diesel. Are they all the same or year specific? Do the manuals do a good job taking you thru a repair job?
And finally, the tractor's got about 5200 hours on her. What other overhaul work needs to be done at this time?
I've had her now for about three years and she's a great rig. Moved a lot of snow, dirt, and brush. I expect to keep her going for a long time so any advice you'all have it greatly appreciated. Thanks for helping out!
Joe(TX)
06-05-2004 04:07:03
 Re: Several questions in reply to Sean, 06-04-2004 12:12:01
It sounds a little like a head gasket although it could be a cracked head.
The tractor serial number on the bell housing would make it easier to id the year. There were not many changes in the engines over the years built on the 180. Most of the manuals will give you the information needed if you have some mechanical ability. I usually get both the factory and the IT manuals. Sometimes one has additional info the other doesn't have.
