gear lube
Dan
06-03-2004 19:36:17
I have a 1939 AC,WC. I need to know how to check the levels of the gear lube in the trans, differential and final drives. Also where do you add more oil for each one?
wdtom
06-05-2004 19:03:04
 Re: gear lube in reply to Dan, 06-03-2004 19:36:17
There will be a plug on the side of the transmission. About half way up the side, fill to that level. Somewhere on the rearend there will be a plug too, about half way up it. I don't know about the final drives, they are not usually filled as much, look for a plug about 1/4 to 1/3 of the way up these. Maybe someone else with a WC that knows more than I do about them will go into a little more detail.
