WD Hand Clutch-disengaged
rw
06-03-2004 07:11:45
When I purchased my WD the hand clutch had been disengaged and I would like to put back into use. The hand lever, yoke and shifter shaft are all conected and functioning but it is not operating the clutch. Apparently something has been disconnected internally, perhaps it is just the set screw on the fork. How have you seen the hand clutch disconnected and how would you go about re-connecting it? What would be the best way to do this, take off the battery box and go from there? Thanks- you have been great help!
wdtom
06-03-2004 18:18:17
 Re: WD Hand Clutch-disengaged in reply to rw, 06-03-2004 07:11:45
Yes, takeoff the battery box and have a look. Try to get a manual so you know what to do with what you find. These are good clutches and can take a lot of abuse as they run in oil, but they can wear out or things could loosen.
