AC WD Identification
Chris
06-03-2004 06:39:31
Okay, I purchased a AC WD for $1900 from a fellow in Illinois. He originally thought it was a WC due to the stickers. However I know the stickers are wrong. I know the tractor is a WD but I have a sneaking suspicion that it is a WD 45. The right side of the motor has a solid cover plate on the engine block suggesting WD 45. Am I accurate in my suspicion?
John
06-03-2004 15:48:19
 Re: AC WD Identification in reply to Chris, 06-03-2004 06:39:31
If there is a plate on the block behind the distributor or mag it is a WD, the WD-45 did not have a plate, the block was solid. Most anything else could have gotten changed over the years but it's almost impossible to get rid of that plate if the block had one, or add it if it did not. Of course this is not to say that someone couldn't have put a 45 block in a straight WD or a WD block in a WD-45. Also the WD engine could be built up to near WD-45 performance.
rw
06-03-2004 07:15:32
Click on "serial numbers" to the left under "Research and Info" and follow the links to AC serial numbers. That will tell you the model, year and where to look for serial numbers.
Chris
06-03-2004 07:40:10
 Re: Re: AC WD Identification in reply to rw, 06-03-2004 07:15:32
The numbers I got from the owner were.
WD3000232PA
I will look tonight myself on the left transfer case.
Thanks,
Chris
John (C-IL)
06-03-2004 16:26:12
 Re: Re: Re: AC WD Identification in reply to Chris, 06-03-2004 07:40:10
Those are the engine numbers which would indicate that you have a WD. WD45 engines start with 45-XXXXX
