what weight oil
Dan
06-02-2004 17:06:45
I have 1936 AC WC, it has a power take-off unit but no hydrolics. What oil is recommended for the Trans and the final drive?
Gene
06-02-2004 22:05:15
 Re: what weight oil in reply to Dan, 06-02-2004 17:06:45
The owners manual says:
Transmission- 140 WT gear lub. for temperatures above 32 deg. and 90 WT below 32 deg.
Final Drives- above 32 deg. 250 WT gear lub and below 32 deg. 140 WT gear lub.
Differential- 140 WT above 32 deg. and 90 WT below 32 deg.
What do I use. 90 WT gear lube in all three.
