WD manifold gaskets ??
rw
06-02-2004 05:50:51
I am seeking advice on putting new manifold gaskets in my WD. Page 43 of the owners manual shows a round gasket and a retainer. I picked up the gaskets set locally (FEL-PRO # MS 8605-3)and it has seven round metal retainers with a gasket apparently inside and two that have the same size hole but are not round- they are elongated on both ends. Do the gaskets sound correct and how are these odd numbers supposed to go on the six manifold ports?
Ron
06-02-2004 19:57:42
 Re: WD manifold gaskets ?? in reply to rw, 06-02-2004 05:50:51
While I was installing mine a few yrs ago, I used High-Temp Silicone on the asbestose rings...rubbed it in real good...Sure seems to be holding up good, and it kept all the rings and cups in place while I slid it all in place...!!
Use anti-seize on the studs, and you will thank yourself, next time..!!
Brian G. NY
06-02-2004 07:41:33
Seems like the last set I got (a few years back) had the same stuff as yours. I just used 6 of the round ones and put the others away for whatever.
