a c crawler question about a hd 6 crawler
dave
06-01-2004 08:12:22
I am looking at a hd 6 crawler loader. the guy is selling it to settle a estate.
it has the g.m. engine in it.
I was wondering where you guys got parts for old a.c. crawlers.
dave
jdemaris
06-01-2004 20:11:24
 Re: a c crawler question about a hd 6 crawler in reply to dave, 06-01-2004 08:12:22
HD6s did not have G.M. engines. HD5 had a G.M. Detroit Diesel, but it was replaced with the HD6 that used a 344 cubic inch Buda engine. I have no trouble getting parts for mine.
Dale(MO)
06-02-2004 02:53:29
 Re: Re: a c crawler question about a hd 6 crawler in reply to jdemaris, 06-01-2004 20:11:24
In reply to jdemaris, if I'm not mistaken, Allis Chalmers used Detroit Diesels in every model to the HD16 for certain. It wouldn't surprise me at all if the HD6 in question has a Detroit. It just means that it is anything but new. They also don't have the power of the Buda engine, but that's the difference between 2 cylinders and 4 cylinders.
jdemaris
06-02-2004 05:58:28
 Re: Re: Re: a c crawler question about a hd 6 craw in reply to Dale(MO), 06-02-2004 02:53:29
Detroits in "every model to the HD16?" NOT TRUE. What information do you base your claim on? I'd like to see some sources. I own a 1954 HD5 with a Detroit Diesel 2-71 (142 c.i.), and also own two HD6s, both with Buda four-stroke 344 c.i. engines. ALLIS NEVER MADE AN HD6 WITH A DETROIT. I also have an H3 with an Allis four-stroke gas engine and an HD4 with an Allis four-stroke 200 cubic inch diesel. So, there's an H3, HD4, and HD6 - all NOT using Detroits. And . . . by the way, the HD16 does not have a Detroit either and neither does the HD11. I have the Allis Chalmers production records here in front of me, and they read: HD5 produced from 1946 to 1955. It was replaced in 1955 by the HD6 which utilized the four-stroke Buda 344 cubic inch engine and production continued through 1974.
Russ
06-03-2004 17:43:10
 Re: Re: Re: Re: a c crawler question about a hd 6 in reply to jdemaris, 06-02-2004 05:58:28
HD6 In jun types; Looks like JD has all the data
to cover this one!
Dale(MO)
06-03-2004 02:50:01
jdemaris, There used to be a parts supply house I dealt with several years ago in North Dakota called Surplus Tractor Supply. Their listings were by model number and engine type - either Detroit or Buda - from the HD5 to the HD21. I never dealt with Allis tractors, they were never popular in my neck of the woods. I know the 3 & 4 had Allis motors - I own an HD3. Sorry, I don't have their production records to quote from. I guess my two-cents-worth isn't worth that much. Sorry to bother you with my junk facts.
Kevin (FL)
06-02-2004 07:23:43
My AC manual for the HD series doesn't list the Detroit until the HD 7 model. The manual I have for the HD6 only list the 344 AC engine--no reference to the 2 cycle Detroits..My 80 year old mechanic buddy has a 6G that had a 271 in it but it wasn't factory. (No engine in it now.) I believe with the "spicer shaft" setup between the engine/rockford clutch and tranny, it was easy to install just about any engine that would fit. He said I could have this one, but I haven't decided what to do with it. Looks like a big job just to move it.
jdemaris
06-02-2004 18:37:37
 Re: Re: Re: Re: Re: a c crawler question about a h in reply to Kevin (FL), 06-02-2004 07:23:43
I've seen quite a few that received engine swaps. The HD6 is basically, just a HD5 with the updated engine so it doesn't take much to swap engines. I looked at an HD5 today that has a Chrysler gas engine in it. But, again . . . HD6s were never made with Detroits. The "6" designation evolved after AC had a dispute with G.M. and took on the Buda engines to replace the Detroits.
dave
06-02-2004 08:08:09
The guy I talked with said it was a 3cyl gm engine.
Kevin (FL)
06-02-2004 22:09:20
 Re: Re: Re: Re: Re: Re: a c crawler question about in reply to dave, 06-02-2004 08:08:09
The 3-cylinder will fit too. Is it a 53 series or 71 series?
dave
06-03-2004 18:12:24
 Re: Re: Re: Re: Re: Re: Re: a c crawler question a in reply to Kevin (FL), 06-02-2004 22:09:20
it is a 3-71 gm engine.
are there still parts available for this engine?
jdemaris
06-03-2004 19:46:59
 Re: Re: Re: Re: Re: Re: Re: Re: a c crawler questi in reply to dave, 06-03-2004 18:12:24
Yes, Detroit Diesel parts are easy to get, new and used.
dave
06-04-2004 07:14:26
 Re: Re: Re: Re: Re: Re: Re: Re: Re: a c crawler qu in reply to jdemaris, 06-03-2004 19:46:59
Okay, now that i know about the engine. how about the undercarriage. he says it is 85% on the good side or 15% worn. where do you guys get parts for the undercarriage? also, steering cluthes are important with crawlers. can you still get ac steering clutchs?
