Does anyone have a manual for a Allis Chalmers twi
Nicholaus Sowde
05-29-2004 11:46:53
Does anyone have a manual for a Allis Chalmers twin wheel drive sickle bar mower? If anyone does I would like to buy it. If it is for sell. Thanks
Eldon (WA)
05-29-2004 20:05:11
 Re: Does anyone have a manual for a Allis Chalmers in reply to Nicholaus Sowder, 05-29-2004 11:46:53
Which one do you have? There is the #7 which is rear mount and uses the snap coupler bell, the newer 80R which is rear mount and doesn't use the sc bell, but has a bracket that mounts where the drawbar bail usually goes. It has a cable lift going to the RH lift arm. Then there is the 80R3 which is the 3pt version, and then there is the 80S which is a belly side mount with a cable system going to the Left rear lift arm for lifting. The last model was the 82R which was a 3pt model with a tail wheel and the 82S which is the side mount version and uses a hydraulic cylinder to lift itself.
I have a manual for an 80R3 for sale....
Nicholaus Sowder
05-30-2004 10:35:46
 Re: Re: Does anyone have a manual for a Allis Chal in reply to Eldon (WA), 05-29-2004 20:05:11
I have the three point version that has the belt and no tail wheel. How much would you want for your manual? Thanks
