WD-45 brake anchor pin
George G
05-27-2004 17:07:10
I'm trying to remove the brakes off my 45. I made a puller to hook under the head of the anchor pin, and hook to my slidehammer. The pin won't budge. So, I was wondering, can you pull the final drive out first, then remove the brake shoes. I guess the big qustion is, Will the shoes spread open far enough for the drum to slide out.
Thanks for your input.
John (C-IL)
05-28-2004 19:05:51
 Re: WD-45 brake anchor pin in reply to George G, 05-27-2004 17:07:10
Swearing may not help but it will make you feel better.
JMS/MN
05-27-2004 19:44:29
Lots of tips in ARCHIVES regarding getting that miserable pin out. I like using a 1/4 by 2 by 8 inch flat iron, drill a 3/4 hole near one end, and weld it onto the pin. Heat of welding may loosen the pin, and you can whack on the lever to rotate the pin.
