Model B Plow
Reggie
05-27-2004 13:43:36
We came up with a single bottom plow for a"B". It has the lift lever and pivoting arms but we are not sure how it mounts.Does anyone have a manual or pictures. It would be greatly appreciated. Thanks Reggie
Rod (NH)
05-27-2004 18:02:59
 Re: Model B Plow in reply to Reggie, 05-27-2004 13:43:36
Hi Reggie,
If your plow is the typical one from AC and is the manual lift version, here's a picture of the basic hookup. The right hand plow is shown. The left hand one is similar but to the opposite hand. The arrangement for the hydraulic lift version is a little different regarding the lifting mechanism.
third party image Rod
Reggie
05-28-2004 04:17:44
 Re: Re: Model B Plow in reply to Rod (NH), 05-27-2004 18:02:59
Rod thanks for the responce it helps alot.I can see that we are missing the nearest lift lever and the hitch bracket for the front end of the plow. Is this photo out of a manual? Could I get the parts # page? Where can I get this manual?
Can I get a phone # or e-mail? Thanks again
Rod (NH)
05-28-2004 10:09:11
 Re: Re: Re: Model B Plow in reply to Reggie, 05-28-2004 04:17:44
Reggie,
If you don't have that particular lever and hitch bracket you may have the hydraulic lift version, especially if you do not also have the long spring shown. The two pictures are scanned from a partial manual that I have. It is not complete and is missing the parts listing portion that fully describe each part. I understand all manuals are still available from AGCO-ALLIS. Go to agcocorp.com on the net and poke around until you find the dealer locator. Then check out the nearest AGCO-ALLIS dealer to you. That should give you any contact info. The part number on what I have for a partial manual is "TPL-178 C" and the title is "Operating Instructions "B_C" 1-Way & 2-Way Mounted Plows".
