HYDRAULIC CYLINDER ON AC D10
Jim E. SIMS
05-12-1999 19:35:46
MY CYLINDER WILL PICK UP BUT WILL NOT LET DOWN. DOES ANYONE KNOW WHAT THE PROBLEM COULD BE.
Lacy
05-13-1999 10:31:21
 Re: HYDRAULIC CYLINDER ON AC D10 in reply to Jim E. SIMS, 05-12-1999 19:35:46
Sounds like the spool valve. If the cylinder has lift power your cylinder probably is good. If you can try and switch the cylinders in-out lines to the spool valve, once you do this it should go down but not come up, this would be a valve body problem.
JIM
05-15-1999 10:24:43
 Re: Re: HYDRAULIC CYLINDER ON AC D10 in reply to Lacy, 05-13-1999 10:31:21
THE TRACTOR IS A 1965 D10 SERIES 3 WITH THE THREE SPOOL HYDRAULIC SYSTEM. I NEED A DIAGRAM THAT DETAILS THE HYDRAULIC SYSTEM . DO YOU KNOW WHERE I MAY OBTAIN ONE.
Joe Oligschlaeger
03-09-2000 18:45:02
 Re: Re: Re: HYDRAULIC CYLINDER ON AC D10 in reply to JIM, 05-15-1999 10:24:43
I can photo copy if still in need.
