Need Help Identifying Carb
John
05-12-1999 16:14:51
I am trying to identify a Zenith carb from an early AC WF tractor. There is around tag on top of the carb, but part of the numbers have been destroyed. The inner circle of numbers are OK and are 7078C. I can read a portion of the outter circle of numbers as 3195. I ordered a WF kit from CT Farm & Country but it is the wrong one. Any help on how to identify the carb and get the right kit would be appreciated.
John Van Eps
05-16-1999 05:22:19
 Re: Need Help Identifying Carb in reply to John, 05-12-1999 16:14:51
JOHN, I did some furthur checking on the carb. Your Zenith carb needs a ck-8601 kit manufactured by Niehoff. If you have a Checker, Schucks or Kragen Auto parts store they can get them for you! Just for information if you have a Marvel-Schribner carb, the kit is ck-8505.
Aaron
05-12-1999 16:48:44
You have a part number U-3195 carb and the second number 7078-C is the early one used on WF's prior to S# 1904. I know for fact that complete kits cannot be obtained for this carb, as it is the same one on my WC. Try your AGCO dealer. They still have some part by part stuff, but no kits. TISCO has a gasket kit, but no complete kits. Hope this helps.
Aaron
John Van Eps
05-15-1999 08:05:40
 Re: Re: Need Help Identifying Carb in reply to Aaron, 05-12-1999 16:48:44
Take the numbers from Aaron and go to you checker auto supply store and they can get you the kit you need!
