WD magneto parts
Mark A
05-25-2004 08:02:11
Where can I get a condenser and points for a WD with a MAGNETO? I looked under tractor parts, and there is a tuneup kit for, what appears to be, a distributor type but not for a magneto typ. Am I looking in the wrong place? There are also kits to convert to 12 volts. I dont want to do that. I just want points and a condenser only for this WD. Thanks in advance.
Steve in N.J.
05-25-2004 20:38:23
 Re: WD magneto parts in reply to Mark A, 05-25-2004 08:02:11
Mark,
We do complete mag rebuilding and repairs. We have in stock all kinds of parts for the different Fairbanks models used in the AC line of tractors. Drop us a line for pricing...
Steve/B&B Custom Circuits
[email protected]
Gene
05-25-2004 09:51:41
Forgot to add. You will need a 12 volt alternator or generator to charge the battery. Go with the Delco single wire alternator. Kits are available or try the local auto salvage yard.
Gene
05-25-2004 09:45:10
Orscheln has the parts hanging on the wall for magnitos. Try the local autoparts store. I bought the points and condensor for a Fairbanks - Morse magnito from the local autoparts store.
Converting the starter to a 12 volt system is fairly simple. Install a 12 volt battery. If the tractor has lights change the bulbs to 12 volt.
Keep the magneto ignition.
