WD 45 pto shaft
jim hynden
05-24-2004 04:55:14
On my WD 45, where the pto drive shaft connects to the pto box at the front of the shaft, there is a 4" piece of 1 1/4" gas pipe that someone has drilled through both ends and bolted the shaft to the drive motor. I discovered this when I hit a concealed object when brushhogging and this pipe sheared. Both pieces that it was connecting are round shafts ( approx 1 1/8 to 1 1/4 ) with a both hole through each about 3/4 " from the end. Can someone tell me if there is supposed to be a u-joint assembly there or something? If you have a diagram or parts manual of some sort that shows this assembly, I would greatly appreciate an email. Thanks, Jim
bstrucker
05-24-2004 08:04:08
 Re: WD 45 pto shaft in reply to jim hynden, 05-24-2004 04:55:14
The picture that I have in an IT shop manuel looks like the front of the shaft is belled to fit over another shaft with a cross bolt threw it.If I had your email and a some more info,so I send the right info,I'd try to send it to you
