WC two-speed
brad deplazes
05-21-2004 21:53:02
i have a wc with a hi-lo gearbox behind the tranny does any body know anything about this. it appears to be factory made as it bolts right in
Frank
05-24-2004 17:38:35
 Re: WC two-speed in reply to brad deplazes, 05-21-2004 21:53:02
If it is a gearbox it is probably a Sherman, it is either a step up or step down but not both. You can't tell from the outside what it is.
bdeplazes
05-25-2004 18:15:38
 Re: Re: WC two-speed in reply to Frank, 05-24-2004 17:38:35
i have heard it called a sherman before and have also heard of other tractors with a sherman two-speed. does any body know anything about sherman?
Frank
05-26-2004 03:06:12
 Re: Re: Re: WC two-speed in reply to bdeplazes, 05-25-2004 18:15:38
The Sherman for a Ford was a step up and step down together but the one for the WC was a direct and up or a direct and down but not both together.
bdeplazes
05-25-2004 18:18:21
also, thanks for the replys
Gene
05-24-2004 19:22:37
I didn't realize that there was an aftermarket gear reduction for the WC's. I'm working on my Grandfather's 36 WC and have a 38 WC parts tractor with the "disconnect" behind the transmission.
My Grandfather purchased the tractor when my father was 7 years old. It was the only tractor my grandfather ever owned. My Dad hates the tractor with a passion. I suppose that as a farm kid he had to operate it - for years. Actually my Dad used the tractor for farm chores in the 70's. 30 - 40 years with the same tractor. I'd be pretty sick of it to.
Thanks again for the information.
Gene
05-24-2004 14:47:09
It's probably not a high/low gear arraignment. In 1938 Allis added a disconnect between the transmission and differential. The purpose of the disconnect was to power the PTO shaft and stop the forward motion of the tractor. Used when bailing hay.
JMS/MN
05-24-2004 21:10:32
 Re: Re: WC two-speed in reply to Gene, 05-24-2004 14:47:09
Also used to raise the cultivator when stuck, too close to a fence, etc. Power lift was driven from between the transmission and that throwout lever. Without it, the wheels had to be moving forward to raise the cultivator. I've never heard of a two-speed either, but who knows what might have been invented. I have seen clutches that fit in that same area, and provided live pto power for baling, etc.
