Model C - goes into gear without clutch and won't
Billy
05-19-2004 21:13:23
I mowed with the tractor this am had a funny sound while taking off on 2nd gear with PTO engauged. Sounded like it was tring to jump out of gear but did'nt. I mowed for another 30 min. stopped. came back later ro move tractor and now I have nothing. Any HELP...
J. Willis
05-20-2004 14:25:32
 Re: Model C - goes into gear without clutch and wo in reply to Billy, 05-19-2004 21:13:23
Billy; Does it go into any gear without the clutch or just second and third?? If the shift fork(s) appear normal, then you're problem could be more sever. If it will go into all gears, running, without the clutch. Then I would suspect the clutch hub may have broken out of the clutch disk or the pressure plate springs have broken, (less likely). In extreme cases, the input shaft, bearing or gear may be faulty. What sort of noise was the transmission making, does it make a simular, less sever, noise while moving the tractor without the PTO? Whining somewhat is normal for these old girls, unless of course, the tranny has been re-built. Grinding, growling, screeching, rumbling and chattering is a heads up that something is about to go south. Hope this helps, John
Billy
05-20-2004 20:14:51
 Re: Re: Model C - goes into gear without clutch an in reply to J. Willis, 05-20-2004 14:25:32
John, The noise sounded like it was tring to jump out of gear with the PTO enguaged. don't remember if it did it without PTO enguaged. This sound only happened once and went away once I started going. She has been grinding alittle trying to get her in gear for some time now. I mowed for about an hour with no problems. I got bogged up in grass and dirt and stalled the tractor, a slow stall not a hard clump. decided to break for lunch when I came back she would'nt move.
Dick L
05-20-2004 07:09:16
Pull the side cover off the transmission. If a fork has worn down or bent, repain and reassemble.I have seen the shift leaver pop out of place as well. You will not be able to tell untill you remove that cover that has the forks attached as an assembly. Kinda tricky getting every think lined and back in place but it can be done. Very few times have I slid it back on the first try with the transmission on the tractor. The biggest problem is bumping one of the slide gears while trying to get the forks in the grooves on the gears. You will see what I mean when you get it apart. Don't give up they will go togather. I about lost my cool on one out in a wet plowed field, but I was able to get it in.
Dick L Gotta Quit That
05-20-2004 07:13:28
 Re: Re: Model C - goes into gear without clutch an in reply to Dick L, 05-20-2004 07:09:16
Proof reading after hitting the post button. I keep getting a blank box after hitting the back button.
Soo REPAIN was REPAIR and THINK was THING
