WD Horsepower?
Chuck
05-17-2004 19:54:25
I am looking at a WD but have not found out how much horsepower. Plan to use 9 foot haybine, can it be done?
Thanks
Bob Semrau
05-17-2004 20:30:55
 Re: WD Horsepower? in reply to Chuck, 05-17-2004 19:54:25
I believe that a WD has 34 PTO hp. My JD 480 haybine (8' 9") says in the manual that it needs a minimum of 35 hp to run it, but my WD doesn't seem to care that it's 1 hp short. You'll probably be OK. The hydraulics will be the tricky part - WD's are high pressure, low flow. I use a 2" x 8" cylinder - you don't want to go any bigger than that.
JMS/MN
05-18-2004 11:23:58
 Re: Re: WD Horsepower? in reply to Bob Semrau, 05-17-2004 20:30:55
Physical size of the hydraulic cylinder has nothing to do with the pressure that it can withstand. Any cylinder is built to withstand a certain pressure, and the lift capacity (pounds) is determined by it's diameter, and the pressure exerted upon it. The stroke length indicates how far the rod will push the fulcrum, and has nothing to do with the pressure and volume of the cylinder. The speed of operation is determined by the pump volume.
Bob Semrau
05-20-2004 12:50:18
 Re: Re: Re: WD Horsepower? in reply to JMS/MN, 05-18-2004 11:23:58
Physical size does matter in relation to how much hydraulic oil is available in the system. I was basically quoting the WD operator's manual here ...
