Correct Hyd. Fluid for D17
c.jackson
05-11-1998 18:55:30
Working on my first D17. What is correct Hyd. fluid for early D17?
randy
05-11-1998 20:20:40
 Re: correct Hyd. Fluid for D17 in reply to c.jackson, 05-11-1998 18:55:30
: Working on my first D17. What is correct Hyd. fluid for early D17?
the correct hydraulic fluid in the early models i believe is sae30nondetergent motor oil.
but, you can use allis chalmers 821 power fluid or any standard tractor hydraulic oil.
remember that you have two places to check oil close to the gear shifter, one is on the right side sitting in the seat.
it is the transmission/differential and the other is on the left and forward of the transmission dipstick. it takes a wrench to remove and is easily
overlooked if youre not familiar with the tractor. and dont forget that you must check the final drives seperate from the rest of the fluids.
good luck and if i can help feel free to yell. im from western ky. and would be happy to help you if i can. ive been associated with allis chalmers for about 30 years now. and im only 40. good luck, randy
