broken clutch??
jared
05-16-2004 17:11:48
I left my sitting for a couple weeks, ran it once, ran it again today and the clutch won't let go, everything seems to move fine. Anyboby else with this prloblem?
steve
05-16-2004 17:53:46
 Re: broken clutch?? in reply to jared, 05-16-2004 17:11:48
the rear crank shaft seal leaks slowly over the years and has covered the plates and "stuck" them together. leave it in gear and start up and run with clutch pushed in. run around and pop it to see if it comes loose. push it up aginst a wall front or back, put it in gear (F or R) and crank with the clutch pushed in to see if it lets go. after you get it loose, push the clutch in and peg it down. remove the starter from the hole. spray the clutch thru the hole and bottom hole with a weed sprayer filled with laundry soap and water. do it twice, let it set, spray off with the garden hose. reinstall starter and run for another 20 years.
