Allis Chalmers 2200 diesel inj hand pump
barryinmn
05-14-2004 19:19:25
Can anyone point out the hand pump on a roosa master injector pump? Tractor is a 1970 Allis Chalmers 615 TLB with the D2200 diesel 4 cyl engine. I'd like to change the fuel filters but want to be sure it'll run again after. injector is a model DBFGC-437-5-AG
Does this engine have the same power as the gas 160 power crater. I'm thinking about 40HP?
barryinmn
05-15-2004 21:04:38
 Re: Allis Chalmers 2200 diesel inj hand pump in reply to barryinmn, 05-14-2004 19:19:25
Thanks for the tips. Machine has been on Uncles farm since '81. I contracted out replacing pins bushings & hydraulics in '02. In '03 I pulled the starter for rebuilding. Just now getting to the "easy" stuff.
jdemaris
05-15-2004 20:03:09
Allis Chalmers rated the engine at 52 horsepower. I've got the same engine in my Allis HD4 dozer (D2200 - 200 cubic inches). With my machine, there is no external fuel-transfer pump. The Roosamaster DB injection pump has it's own small transfer pump built into the back of it. It draws fuel and also makes the injection timing advance work. My crawler DOES have a hand-primer pump that is used for filling and bleeding the filters after changing.
bstrucker
05-15-2004 19:15:05
If there is a primer it should be on the lift pump.If your tank is higher than the engine,it may not have a primer.You just crack the bleed screws and let gravity take over.
