The 3 Pt Toplink adapter bracket that clamps around the rockshaft work the best, but are real hard to find. I recently saw one go for better than $120 on ebay. Like you, my WD45 had one of these ones on it. I've never been able to find a manufacturor of these. Most 3 Pt. Conversion kits include some sort of U-shaped bracket that simply wraps around the rockshaft. My WD had one of these, and I really think it is a poor design. Even if you use muffler clamps to keep the bracket from sliding side to side on your rockshaft, there is nothing to keep it from rotating to and fro on the same shaft. I've bent several toplink rod ends when the U-shaped brackets rotate too far. This especially seems to happen when using an implement in reverse operations, such as a back blade or box blade work. We're currently in the process of manufacturing one of those clamp-style brackets (Dad has a Bridgeport). Bought the materials two days ago, don't have it finished yet. After trying it out on the WD, we're considering manufacturing some more for resale at shows or possibly on Ebay. Anybody out there interested? It seems to me that there could be a sizable market out there for these clamp-style top link brackets, the ones that securely clamp to the rockshaft and won't slide back and forth or rotate around the rockshaft, maintaining correct 3 pt. geometry at all times. I struggled for a long time with the U-shaped style bracket on my WD, until I bought the '45 and found this clamp style bracket. Would be interested in any thoughts or opinions on the subject. Good Day!
