180gas
danny
05-12-2004 12:51:11
my 180 gas is hard to start. when i get it started it runs rough until it warms up then it runs great. any ideas would be appreaciated.thank you
Denny
05-16-2004 06:55:52
 Re: 180gas in reply to danny, 05-12-2004 12:51:11
This one is a puzzle. I think my first suspicion would go to carburation. Does the carburator ever "run over"? How does the choke affect the running when you first start it? Is gas flow sufficient to the carb all the time. Are there any other symptoms?
Is the shaft for the throttle tight in the carburator? Valves also can cause problems on cold engines. If you've burned "bad" gas, deposits can collect on the valve stems and prevent the valves from closing properly. Generally this problem is less evident at idle and more severe at higher rpm's.
Need more info.
