WD 45 engine numbers
Thomas
05-08-2004 22:06:29
Does the engine # 45-5992-G sound right for a WD45 or a WD? Would $1500 be to much for a fairly clean WD or WD45? What kind of implements could I use with this tractor?Is there a good source for parts and implements in No.Calif.The tractor comes with a disk only and I would like to get whatever else will work with it. I'm new to tractors so thanks for any and all help. Tom
ACEd
05-09-2004 07:54:02
 Re: WD 45 engine numbers in reply to Thomas , 05-08-2004 22:06:29
Motor s/n would indicate an early WD45 motor most likely matching a tractor s/n in the WD151xxx range made in 1st half of 1953 production (the first year for WD45). G suffix is higher compression compared to K which was to burn distillate fuel (kerosene).
It is possible that motor was changed - I have 2 WD45's with earlier motors, but most likely its original and you have a WD45. This is only really important for collecting purposes as the 226 ci WD45 motor was significantly more powerful than the 201 ci WD / WC motors and hence more desirable.
It probably has a snap coupler which allows connection to AC implements, but you could later get a snap coupler attachment that effectively made it a 3-point hitch which you will want in order to use modern implements. Most of these tractors had the adapter if they were in more recent use. Alternately, you could buy a 3 point conversion kit for about $300-400.
Tony C
05-08-2004 22:51:00
That number is a WD-45 block serial number.Should be to right of carb. Tractor serial number is on left rear brake housing. will be WD----- . Lots of equipment for your tractor. Tony in Oregon.
Thomas A
05-09-2004 20:21:26
 Re: Re: WD 45 engine numbers in reply to Tony C, 05-08-2004 22:51:00
Thanks for the help,I found the tractor #,WD151217.
