Pulley for a Woods Mower on a '39 B
Chris (OR)
05-08-2004 14:43:52
Well I got the mower for my '39 B. When you order it there is a warning that the '39 and earlier tractors may have a different taper on the shaft that normally runs the belt pulley.... Woods suggest that you shim up the difference.
I thought this was a bit Mickey Mouse if I am spending $1400 on a new mower to put on a rebuilt tractor...
Thus if you order bug your local belt/bearing supplier, you can order a new pulley and machine it correctly. You should order a Browning Sheave #BK85x3/4. This is a cast sheave. Not quite as heavy as the Woods one but it's not cheap pressed steel. Then machine the bore to 1.160" on the big end with a .063" per inch taper. Broach the key way for a standard 1/4" key. I had to make a tapered broach mandril for that but I will loan it out if other folks want to try this...
Thanks
Chris Horn
Scappoose Oregon
[email protected] (remove .nospam to email....)
