Tuning up model C for more HP
Bill
05-06-2004 20:53:17
any sugestion on what to do first to increase my mowing power
Dick L
05-07-2004 07:34:05
 Re: Tuning up model C for more HP in reply to Bill, 05-06-2004 20:53:17
The first thing I would do is to check the compression. If you check this and the compression is down it will save you a lot of tinkering that don't help. Bad rings or valves can't be overcome by any amount of tuneups.
Bill
05-07-2004 16:31:35
 Re: Re: Tuning up model C for more HP in reply to Dick L, 05-07-2004 07:34:05
Thanks Dick, You have help me in the past. I will check the compression. This tractor has not been started in a couple of years and I know better than to pull her out and expect her to run good. The old tractor has always run good in years past pulling a brush hog. I hoping that a full tune up (wires, plugs and points will bring her back to her old self. Do you think it's possible that setting could have stuck the rings and they might need to re-seat? This tractor has never snoked abit and does not now.
Dick L
05-08-2004 12:26:26
 Re: Re: Re: Tuning up model C for more HP in reply to Bill, 05-07-2004 16:31:35
I somehow got the idea that you were trying to increase the HP of a running tractor that was in use. Sure a good place to start if the tractor has been stored inside would be to check the magneto for a strong spark and then put in a new set of plugs. I would file the points and reset the gap to .020 if they look good and not change them untill after it seemed they might be failing. If it had the proper plug wires with wire cores then they would probly be fime if as I stated it was stored inside. If it was stored outside all bets are off. Even if the rings are not stuck you will have a very low compression after setting for a long time. You would want to put a coupla three table spoons of motor oil in each plug hole and let the engine spin over a short while and the add a little more before taking a compression test. If the compression is in the 60 70 psi range and even from cylinder to cylinder you should not have a problem pulling a bush hog.
Billy
05-08-2004 15:07:47
 Re: Re: Re: Re: Tuning up model C for more HP in reply to Dick L, 05-08-2004 12:26:26
Thanks again Dick, I will post my success
wdTom
05-08-2004 18:33:49
 Re: Re: Re: Re: Re: Tuning up model C for more HP in reply to Billy, 05-08-2004 15:07:47
If it has set with gas in the tank for a year or two you could have bad gas. The gas now can go bad in a few months. try draining it all out and putting in a few gallons of fresh gas and see how it runs. The tractor pullers around here have to drain out the gas that sat all winter in the spring, or run it out before the tractor will run good sometimes.
ralph friedemann
05-10-2004 13:55:56
 Re: Re: Re: Re: Re: Re: Tuning up model C for more in reply to wdTom, 05-08-2004 18:33:49
I have a AC 1952 CA. I cleaned the gas tank, put on new filter,carb. It starts and runs good, but when I drop a rearend mower it will not take the load. Can someone help me? Loosing power. Please Hurry, I have weeds coming up my backside.
Bill
05-11-2004 20:44:26
 Re: Re: Re: Re: Re: Re: Re: Tuning up model C for in reply to ralph friedemann, 05-10-2004 13:55:56
Ralph,
Sounds exactly like my tractor, but I hannt had a chance to get back to work on it. I will let you know my results and I would like to hear how your tractor comes out..
Thanks
Bill
ralph friedemann
05-12-2004 04:33:25
 Re: Re: Re: Re: Re: Re: Re: Re: Tuning up model C in reply to Bill, 05-11-2004 20:44:26
Bill: It is running like a top. It was all in the fuel. Not only cleaning the whole fuel system but in adjustment. I did clean plugs and cleaned contacts to starter, battery and replaced some bad wiring. At least yesterday the "weeds" got their lunch. Hope it keeps running so good.
Thanks to Tom's help. Oh, I also put a new fuel filter on that had a extension into the gas tank that would stop particles from coming directly into the system. Rust is always a problem, it seems.
Dick L
05-10-2004 14:14:30
Start with the check list above and do a compression. Low compression low HP. As the compression goes up, so goes the HP. If the compression is good on the check look at the carb and fuel flow again. You might want to check the timing with a light but if it starts and sounds good it probly aint to far off.
ralph friedemann
05-12-2004 07:47:52
 Re: Re: Re: Re: Re: Re: Re: Re: Tuning up model C in reply to Dick L, 05-10-2004 14:14:30
Dick: Compression was fine. Fuel was the problem. Maybe along with some wiring problems. Ran like a top yesterday. Thanks for the help.
