3-point hitch sickle bar mower
Sam
05-05-2004 12:42:35
I purchased a CA complete with a rear-mount 3-point hitch sickle bar mower, that appears to be Allis - mounting parts seem to be original - i.e. not modified.
Also, I am co-owner of another CA complete with this same rear-mount 3-point hitch sickle bar mower. Seems to be standard issue.
I am not able to identify the model. It is a pickup-type mower with no side or rear wheels.
Can someone identify the model? And if so, where I may be able to procure a copy of an operator's/service manual for this mower?
RMD
05-08-2004 12:31:11
 Re: 3-point hitch sickle bar mower in reply to Sam, 05-05-2004 12:42:35
The CA never had factory 3-point hitch, so it's hard to say what you have. A common AC mower on a Snap-Coupler hitch is the No. 7. The No. 7 attached directly to the Snap-coupler bell and lift arm latches. The No. 7 was replaced by the 80R which used a special bracket for the lower mounting points. There was a 3-point version of the 80R, called 80R3. Later versions of these (with little change) where the 82R and 82R3. Of course a lot of other manufacturers also made 3-point hitch sickle bar mowers. Literature on the AC No. 7 and 80R/80R3/82R/82R3 is relatively common and can be found on e-bay and other venues.
