G axle length
Marshall
05-04-2004 15:15:39
I just finished painting an A.C. G. When we took it to a show we found that the axle housings were shorter than the other Gs. Some said they were cut by someone after it left the factory, they look original!Did the factory make any short axle Gs? The tie rods are shorter also.It came with a Woods belly mower. The tread width is about fortythree inches when the centers are reversed,which is the only way they will fit!!
Dick L Yes
05-05-2004 06:45:53
 Re: G axle length in reply to Marshall, 05-04-2004 15:15:39
They did make a shorter axle and housing. The last I knew Roger VanCamp had a set that he wanted to place on one of his G's. At this moment I can not remember what the narrower axle setup was for. I am sure someone on here has the skinny.
Dan Spencer
05-05-2004 07:42:49
 Re: Re: G axle length in reply to Dick L Yes , 05-05-2004 06:45:53
Hi,
My 1949 G was purchased brand new in 1950 equipped with a woods belly mower. It has the short axle so I assume this was a dealer set-up.
