D14 Oil Flow
Don Dittmar
05-03-2004 07:27:39
I was wondering if someone could help me with the oil flow on an Allis D14. I am assuming that the pump draws out of the tube that extends out of the Bell-housing, but that would have it drawing through the filter instead of pushing oil through it. If it does draw out of that tube, the flow is pretty simple. I am assuming that once it draws through the tube it pushes the oil through the block.
steve
05-03-2004 15:57:34
 Re: D14 Oil Flow in reply to Don Dittmar, 05-03-2004 07:27:39
the pump is on the back end of the motor under the flywheel. the suction tube is under the pump and sticks into the oil pan. pump will pump oil out the top, thru the 1/4 inch pipe out the top of the fly wheel housing and into the filter area. you cant see the suction tube from the the pan to the pump. you are seeing the output tube.
