Allis B Won't Start When Hot Until It Cools Down
Henry Knight
05-01-2004 06:35:49
Hi! I have a B that runs fine as long as I don't cut it off or if it doesn't choke down. If it is hot and I cut it off, it will not start until I let it rest about 5-6 hours; However, if it is pulled off, it pops off and starts. Sometimes, if I immediately pull back the gas lever and try to start it, it will start, but not if it sits for over 3 seconds. To run well, I have to keep the choke pulled out about half way. Do you think it is the carb or magnito? Thanks.
scott
06-08-2004 20:48:40
 Re: Allis B Won't Start When Hot Until It Cools Do in reply to Henry Knight, 05-01-2004 06:35:49
I had a problem with my AC "C" but here whenever she warmed up and then tried to restart, I couldn't. Try your magneto. I shopped around and found this guy who was 1/5 the price of anyone. He is retired and does this for a hobby. (I sent him extra cash cause it was so cheap).
His name is Ted, phone #717-624-2618. He was friendly and walked me through step by step when I installed the magneto back. It was simple! My tractor runs like a champ now.
PS: I live in NJ and He I think is out in PA. there is no connection, I just like to pass the good word on.
JMS/MN
05-01-2004 20:38:29
Forty years ago we had the same thing with two tractors- Model WC and a C. Both of them got a magneto rebuild and they worked fine after that. Same problem- died hot, pull started for five feet and would run, but would not start with the battery and starter.
mj
05-02-2004 20:21:44
 Re: Re: Allis B Won't Start When Hot Until It Cool in reply to JMS/MN, 05-01-2004 20:38:29
Yeah...takes more spark to fire a lean mix than it does a rich one! Might be a good idea to run the valves, too....Roger?
steve
05-01-2004 07:00:10
if it was magnito/ coil related it would die on its own, and not just if lugged down. --- since you have to choke the motor to run correctly, you are shutting down the quantity of air thru the carb because you dont have enough fuel.--- my fist guess would be you need a carburetor overhaul, and check the fuel filter, and strainer at the tank.--- when back together i would suggest you check the timing to see when it is firing. A hot motor can not take as much "advance" in spark while cranking.--- if it dont pop or backfire when hot, then i think you are out of gas.
Ron
05-01-2004 20:00:19
 Re: Re: Allis B Won't Start When Hot Until It Cool in reply to steve, 05-01-2004 07:00:10
Mine did the same thing today, hand crank with choke closed no go open choke pull start an BINGO she fire right up. set timing then try hand cranking , wouldn't start pull start one more time, FIRES ( all pull starts were in on an off showers all day). the only thing that came to mine was carb , put her away and told her I'LL BE BACK some other day.
