Allis B 3 Point
Possum
05-01-2004 05:48:55
I just bought an Allis B. It does not have a PTO and hydraulic pump installed. I do have them to install though. I want to install an aftermarket 3 point hitch. Is there anything else I need like a hydraulic tank? I have ordered the manuals for the tractor but they aren't here yet. I have been a Ford person and I'm not familiar with the Allis line. Any advice would be appreciated.
One other thing.
05-01-2004 06:01:36
 Re: Allis B 3 Point in reply to Possum, 05-01-2004 05:48:55
You need a different gasket for the PTO housing. The gasket for PTO with Hydraulics is about 3" higher on the bottom to create a reservoir to hold oil back for the pump in case you nose-down the tractor. There's a picture of it in the parts manual.
Good luck, Charlie
CH
05-01-2004 05:57:52
The OEM hydraulic pump uses the transmissiom/rear end oil. I believe the manual reccommends 20W non- detergent.
Possum
05-01-2004 19:30:02
 Re: Re: Allis B 3 Point in reply to CH, 05-01-2004 05:57:52
Thanx Gentlemen, it appears you guys are as helpful as the Ford and N boards.
