Allis D-17 Jumps out of 3rd and had two differnt s
Bob Fields
04-29-2004 20:33:30
I just brought home a D-17. the "torque Housing # is 67998. That is Ser III. But the rest of the tractor is early,tin,muffler,lights. It also jumps out of 3rd. I like this tractor but how do I fix this and what is the differences in all 4 series?
simon
05-12-2004 17:37:57
 Re: Allis D-17 Jumps out of 3rd and had two differ in reply to Bob Fields, 04-29-2004 20:33:30
I have a trans for a d17 ser1 for sale for 500.00 Let me know if you need more info
wdTom
04-30-2004 18:57:17
I am not a "17" guy, but they were related to 45s so maybe had the same type of transmission. If so I don't think there is anything impossible about getting into it and replacing the parts. These are "constant mesh" transmissions, the parts that are worn are "dogs" on the side of the gear and the "dog" that engages the gear and transfers power to the shaft. If you can find the parts and are up for it, with a manual, and some time and patience you can probably do it if you are a mechanical type. Ask questions here for details, someone will know more about D-17s.
WEL
04-30-2004 06:32:07
I also had a D17 that jumped out of 3rd gear.I was quoted $1600 to fix it. The mechanic at Agco-Allis told me the tractor had to be split in order to access the bad parts. Total parts and labor estimated to be around $1600. I did not have it done but sold the tractor instead. AC had several models that had this problem. I have another D17 series 1 that has no transmission problems at all.
