195? Allis CA - hydraulic lift won't lift
JTZ
04-29-2004 13:04:48
After a few years in retirement, the AC (was my father's first born!) has been brought back to life. Can't seem to get the hydraulic lift to actually lift. Handle moves with the appropriate amount of resistance, but doesn't engage the lift. ANY sugguestions would be appreciated! We've got 100+ trees to plant, and need the plow!!
Dale(MS)
04-29-2004 14:58:34
 Re: 195? Allis CA - hydraulic lift won't lift in reply to JTZ, 04-29-2004 13:04:48
JTZ, PTO needs to be engaged and fluid needs to be up to the mark. Check linkage adjustments etc. Might remove drain plug at the bottom of the hydralic pump (1/4" plug)and see if you have any water there. Just some simple things to check. Dale
AC Dan
04-30-2004 09:14:32
 Re: Re: 195? Allis CA - hydraulic lift won't lift in reply to Dale(MS), 04-29-2004 14:58:34
Of course the PTO must be spinning for the pump to operate.
