3 timing marks on WD-45 fly wheel????????
chad
04-29-2004 07:50:00
Ok I know for setting the valves you need to have TDC. I know on the WD-45 you need to find it on the fly wheel. I pulled the inspection cover off and there are 3 marks on it. One looks to be TDC piston on #1 is up and that mark is painted red.
2nd mark looks like it could be 180 degress from top dead center?
3rd mark on fly wheel had what looked to be the letter F scribed next to it.
can some one please explain these markings to me.
if the red paint is TDC and there is one 180 degrees from it that would be great for adjusting the valves.
thanks for the info
Chad
Butch
04-29-2004 09:01:34
 Re: 3 timing marks on WD-45 fly wheel???????? in reply to chad, 04-29-2004 07:50:00
Can only guess why somebody marked the flywheel as they did but your guess sounds as good as any I can come up with. TDC is used for timing purposes, so is F or fire as some are marked. The F mark is where you time the ignition at full advance, usualy a little above half throttle, with a light. There is no big trick to setting the valves as there is a good bit of rotation where they can be set and there is not even a need to crawl under the tractor to set the roation on a mark as per the book. If basic motor operation eludes you (no s-a implied) go by the manual and start at #1. That mark 180 from TDC will come in handy you can set all the valve in two revolutions.
Gene
05-02-2004 08:06:45
 Re: Re: 3 timing marks on WD-45 fly wheel???????? in reply to Butch, 04-29-2004 09:01:34
Have a WC with 3 timing marks. Two stamped in the flywheel and a painted "F", 180 degrees from the stamped "F".
Reason. Makes the initial timing the engine much easier. Pull the cover on top of the belt pulley housing. Roll the engine over until the # 1 cylinder is coming up on the compression stroke. The painted "F" will line up with a bolt hole centered in the opening in the bell housing. Beats cranking the engine a bit, crawling under the tractor to check the timing marks, cranking the engine a bit, back under the tractor.
