need wd-45 crank info asap
chad
04-28-2004 05:27:27
I need to know what the standard crank journal dia. is for a wd-45 for the rod bearings.
I measured 3 of them to be 2.379 and one 2.376
I want to double check it today and see what size rod bearings I need. can someone give me the standard dia?
please help soon need to order parts today
Randy Varilek
05-02-2004 23:23:48
 Re: need wd-45 crank info asap in reply to chad, 04-28-2004 05:27:27
if the crank has been ground, most machinists will stamp the sizes on the somewhere on the crank
Brian G. NY
04-28-2004 08:00:40
Journal Dia. 2.374 to 2.375 Rod bearing Dia. 2.376 to 2.377 Recommended clearance: .001 to .003
chad
04-28-2004 08:20:57
 Re: Re: need wd-45 crank info asap in reply to Brian G. NY, 04-28-2004 08:00:40
thank you thank you thank you! that is what I needed to know.
I did measure 2.374 when I first got started. I did it fast just to get an idea where I was at. I will go home and re-do it tonight.
thanks again
Chad Penny
