Widen rear wheels
Jim
04-27-2004 19:46:53
I'm trying to widen the power adjust rims om my WD and am having a problem. I don't know if I'm doing it the right way or not. I'm backing up with my foot on the brake to the opposite wheel and it worked fine except the wheel wouldn't go all the way over, it's about 4" shy. I tried several times with the same result. I've got the lock off and the 4 cams loosened. Any ideas?
Eldon (WA)
04-27-2004 21:40:09
 Re: Widen rear wheels in reply to Jim, 04-27-2004 19:46:53
You might have a cheap rim that isn't quite to spec and is too small at that end. I have a rim that is that way and it has jambed the eccentrics so tight I will need to take the wheel apart to get them out. Check for rub marks and you should be able to see where the problem lies. Then take an angle grinder and grind it down. Make sure the eccentrics are backed all the way off first.
