WC or WD?
Mark A
04-27-2004 09:53:50
Yesterday, I was looking into buying, what appears to be a WC or WD or WD-45. I looked all over for the serial number, but did not know where to look, until I looked today on this website. The tractor has a magneto, with "spin-out" rear hub adjustment, and a single front wheel. There are no emblems left anywhere. What could this be, a WC or a WD? Thanks in advance.
Eldon (WA)
04-28-2004 21:44:23
 Re: WC or WD? in reply to Mark A, 04-27-2004 09:53:50
I always look at the RH side of the motor to see if it's a WD or WD45....The WD will have the big flat plate bolted to the block.
chalmersbob
04-27-2004 18:37:45
SPIN-OUT REAR WHEELS WERE USED ON THE WD & WD45.
HAND CLUTCH IS ON RIGHT NEAR STEERING WHEEL
SERIAL # ON FLAT AREA NEXT TO THE LEFT BRAKE HOUSING JUST ABOVE THE BOLT TO HOLDS THE ROCKSHAFT. SHOULD START WITH WDXXXX.
BOB
Bob
04-27-2004 17:44:26
WCs have hand brakes.
Ted Seifert
04-27-2004 09:58:18
Sounds like a WD. WD has hand clutch WC does not
Mark A
04-27-2004 10:09:49
 Re: Re: WC or WD? in reply to Ted Seifert, 04-27-2004 09:58:18
Is the hand clutch the level just to the right, and under, the steering wheel? Also, I forgot to add that this tractor has a single hydraulic outlet near the seat. Still a WD?
INCase
04-28-2004 05:25:45
 Re: Re: Re: WC or WD? in reply to Mark A, 04-27-2004 10:09:49
with spin out wheels and a hyd. outlet its not a WC with a magneto (sp) its not a WD45 early WD's had mag's. Another sign of WD is the battery is right infront of the shifter. WC's had the battey lower on the left frame rail. Being an older WD w/mag I'd bet the gear shift is straight up/down not dog legged like the later WD's and WD45's. Have fun
Mark A
04-28-2004 05:58:50
 Re: Re: Re: Re: WC or WD? in reply to INCase, 04-28-2004 05:25:45
Thanks to all answers. Just reading the posts, I am guessing I have an early WD, with a magneto and the battery just in front of the shifter. Next time I go to look at it, I will find the serial #s, and will buy it. I may have to ask more questions about it. The guy also has about 3 or 4 "C" models also, so I may be busy for a little while. Again, thanks.
