wd-45 rod bearing caps torque spec
chad
04-27-2004 05:56:20
Can someone give me the torque spec for the rod bearing caps for a wd-45.
thanks
Chad
Kevin (FL)
04-27-2004 13:45:30
 Re: wd-45 rod bearing caps torque spec in reply to chad, 04-27-2004 05:56:20
Chad,
Per my I&T manual:
castellated nuts (use cotter pin) 70 ft-lbs
self locking nuts 40 ft-lbs
Make sure you know if you have shimless or shimmed rods. After S/N W45FG1001, they're supposed to be the shimless type.
