Priming an oil pump
Don Dittmar
04-27-2004 05:44:50
I am redoing an Allid d14. I was wondering if there was any convient way to prime the oil pump?
Don Dittmar
04-28-2004 04:45:29
 Re: Priming an oil pump in reply to Don Dittmar, 04-27-2004 05:44:50
thanks for all the help guys. I know this next topic has been a long disputed one, but where is the best place to buy an O/H kit?
Gene
04-28-2004 22:07:59
 Re: Re: Priming an oil pump in reply to Don Dittmar, 04-28-2004 04:45:29
Suggest you call around to the AGCO dealers, Tractor Supply, local auto parts stores, Etc. for prices.
Actually, I get most of my parts for a WD and a WC from Federated Auto Supply, a local auto parts store. Most of the time the local auto parts store meets or beats the catalog prices and AGCO's. The big plus is that I don't have to drive 80 miles to get the parts.
Doug in OR
04-27-2004 19:46:56
All you really need to do is spin the engine after the overhaul. Fill the crankcase with oil. Remove the spark plugs and crank the engine with the starter until you develop oil pressure.
Dick L
04-27-2004 10:08:18
I place a length of fuel line hose over the oil tube that runs to the head and fill with squirt can intill the pump and lines are full. With the spark plugs out I crank the engine over with the battery untill I get a flow of oil over the rocker arms. Hook the oil tube back up and crank the engine again untill I see the pressure on the oil pressure gage. Puter back tagather and starter up.
Dave Grubb
04-27-2004 06:18:42
Not sure about the D14 engine but if you get a source of vacuum on the oil pressure gage port and crank the engine with the spark plugs removed you can get oil through the whole system very quickly. When the oil comes out the gage port the whole system is full as the gage is the last thing to see oil pressure.
