WD45 Prototype???
R.J.
04-25-2004 17:35:06
I just purchased a tractor that is definitely a WD45, but the serial number is not on the back like it's suppose to be. There is a number on the left side of the motor that reads WD254150GA, and there is a 4 stamped on the right side frame about a foot past the foot pedal. Is this a prototype? Any info greatly appreciated.
John (C-IL)
04-25-2004 18:44:41
 Re: WD45 Prototype??? in reply to R.J., 04-25-2004 17:35:06
Your engine serial number would indicate that you have a WD. The WD45 engine numbers start with 45-XXXX. Many times if the rearend housing was replaced the dealer didn't stamp the serial number on the new housing.
R.J.
04-26-2004 12:11:40
 Re: Re: WD45 Prototype??? in reply to John (C-IL), 04-25-2004 18:44:41
Yes, you're right, it's a WD, not a WD45. Any thought as to the number stamped on the right side frame?
John (C-IL)
04-26-2004 18:56:44
 Re: Re: Re: WD45 Prototype??? in reply to R.J., 04-26-2004 12:11:40
It's probably just a production number that was put on the channel from the steel mill, I doubt that there is any significance to it.
