WD hydraulics
Jim-IL
04-24-2004 15:32:56
I just changed over my WD with loader to a wide front. When I put it back together the loader would not lift. Is this because there is air in the line? I had unscrewed the line off of one side of the loader when I did this. What do I do now?/ Thanks.
JMS/MN
04-25-2004 09:17:59
 Re: WD hydraulics in reply to Jim-IL, 04-24-2004 15:32:56
As long as you have the pump valve set right, and get flow through the port you are using to raise the loader, you should get lift. Since the line was opened, air got in and after cycling the lift lever several times, the loader should lift properly. It may shudder and not go up completely at first.
