WD45 diesel or gas
Matt
04-21-2004 14:24:26
I have a WD45 that has a diesel frame, PTO, battery box and four bolt front end but has a gas engine. How do you tell if it has the diesel or gas rear end?
Kevin (FL)
04-21-2004 18:44:52
 Re: WD45 diesel or gas in reply to Matt, 04-21-2004 14:24:26
Matt,
I could be proven wrong, but I don't see why the rear axle assembly would be any different between the gas or diesel models. The horsepower ratings were about the same (about 38 gas & 40 diesel DB HP) & gas speed 1400 RPM & diesel 1625 RPM. The only difference that might show up is the gear ratio of the ring and pinion or the final drive ratios. That info might show up in the service manual specifications, I don't know.
