I Didn't Make The Pull
Dick L
04-18-2004 19:10:34
But I had it up and running by 11 pm last night.
11 pictures that take it up to a point.
ed
04-18-2004 20:35:41
 Re: I Didn't Make The Pull in reply to Dick L, 04-18-2004 19:10:34
looks like an allis c not a b.
Dick L
04-18-2004 20:41:00
 Re: Re: I Didn't Make The Pull in reply to ed, 04-18-2004 20:35:41
It be a B with a narrow front. I bought it from Roger VanCamp. He was sure it was factory. The one picture shows the wear from a wide front on the bellhousing/torque tube. Sooo it has a narrow front from a C.
ed
04-18-2004 21:08:52
 Re: Re: Re: I Didn't Make The Pull in reply to Dick L, 04-18-2004 20:41:00
I'm suprised that there was an allis b with narrow front. I guess I've never seen one. I would check the serial # and verify that it isn't an allis c. The stearing linkage and other things leads me to believe it's not. The serial # is in front of the shifter. If it startes with a b it's a b, if it's a c, it's a c. That is unless someone has replaced the rear end. I wish you good luck with your puller anyway. What did you get the hp up to?
Dick L If You Want To
04-19-2004 12:23:10
 Re: Re: Re: Re: I Didn't Make The Pull in reply to ed, 04-18-2004 21:08:52
Look at more pictures you can see that it is a B and not a C. This picture will show the short final drives and the splined wheel hub that only B's have.
Dick L This Was
04-19-2004 12:45:02
 Re: Re: Re: Re: Re: I Didn't Make The Pull in reply to Dick L If You Want To, 04-19-2004 12:23:10
The old girls first time out after the rebuild in 2001. She beat all the other 2500#ers by 20 feet that day.
Dick L No This Was
04-19-2004 12:46:34
 Re: Re: Re: Re: Re: Re: I Didn't Make The Pull in reply to Dick L This Was, 04-19-2004 12:45:02
forgot the link
