Allis G starting troubles, any ideas??
Jeff
04-17-2004 20:04:38
I am trying to get my G to fire and it isn't cooperating. I have fire to the plugs and the plugs are sparking. I have gas to the carb and when I take the carb off the top of the butterfly is wet so I can assume there is gas getting at least that far? When I took the plug wires and distributor cap off I marked where everything was and put them back on like so. It had run before we started taking it down to clean and paint.
Here is what i have as to that and since I can't find my I&T book maybe someone can tell me if I have the plug wires wrong. Looking at the engine from the manifold side the top wire on the cap goes to the plug at the rear of the tractor.The rotation is clockwise with the firing order I believe to be 1-3-2-4 with #1 plug being at the rear and #4 being towards the radiator. is this right?
I can spray a litle starter fluid into the carb and it will shoot a small flame out the exhaust so something is going up in there.... The plugs aren't wet but being as I don't know didly about a flat head motor I don' know if this is normal or not. Any suggestions are greatly appreciated :)
Jeff
04-18-2004 15:07:05
 Re: Allis G starting troubles, any ideas?? in reply to Jeff, 04-17-2004 20:04:38
Ok now more trouble. I did have the firing order right, just went up and checked it. Any ideas now? If it hadn't been running before I would say the timing but I haven' moved any of that ( don't guess that means it could'n be off though...)If I choke it after a few cranks it will blow a blue flame out the ehaust. maybe I just need to get it out and pull it some? I have seen that work before...
Any other ideas are greatly appreciated! Oh and I did just find the book on it. Now if it only come with mechanic..:)
Keith-OR
04-17-2004 20:31:03
Hey Jeff You have the firing order wrong it is suppose to be 1-3-4-2.
Red
04-17-2004 21:17:48
 Re: Re: Allis G starting troubles, any ideas?? in reply to Keith-OR, 04-17-2004 20:31:03
Maybe you need a nearly new gas tank. I have one.
gmpontsler
04-18-2004 13:35:00
 Re: Re: Re: Allis G starting troubles, any ideas?? in reply to Red, 04-17-2004 21:17:48
looking for a gas tank and a set of fenders for a g let me know the price and the shape they are in
Red
04-18-2004 18:12:53
 Re: Re: Re: Re: Allis G starting troubles, any ide in reply to gmpontsler, 04-18-2004 13:35:00
Hello gmpontsler. Email me about a "G" tank and fender. ([email protected])
gmpontsler
04-21-2004 19:07:51
 Re: Re: Re: Re: Re: Allis G starting troubles, any in reply to Red, 04-18-2004 18:12:53
I am looking for a gas tank and a set of fenders for a G allis let me know the condition and price. Also could use a manifold.
AZ Jack
04-17-2004 20:48:10
Yes the firing order is 1-3-4-2. #1 is on top to the rear. #3 right below it, #4 to the left of #3 and #2 is right above #4 which is on top on the radiator side. This is a long winded way of saying switch your 2 wires on the left and you should be OK.
Jefff
04-18-2004 14:46:53
 Re: Re: Re: Allis G starting troubles, any ideas?? in reply to AZ Jack, 04-17-2004 20:48:10
Thanks for all the info. I just got in from hauling in yet another tractor ( dad needs another hobby...) but ill try changing the wires around tomorrow night. I'll post back one way or another if everything works.::)
thanks alot!!!!
Jeff
AZ Jack
04-18-2004 21:39:07
 Re: Re: Re: Re: Allis G starting troubles, any ide in reply to Jefff, 04-18-2004 14:46:53
Please do post and let us know what you find-you have my curiosity aroused as to what the problem might be. Jack
