D14 Throttle Problem
Mark G
04-17-2004 12:05:50
I have a '58 D14 that is a good running tractor with a interesting trottle problem. When the throttle lever is in the low to mid range area it works just fine, but when I go to full throttle it wants to die right before I get to full throttle. Once I am in full throttle it recovers from this and revs up to the proper RPM. If I them move the lever back from full just a bit (an inch or so) it will die again unless I throttle back to about mid-way. It does this under load or with no load. Once I am at full throttle is stays at full throttle except for the following conditions under load; make a hard turn or hit a little hill or something. If I am moving it generally will not die, but just sputter a bit and then pick back up. On a hill it will sputter, then pick up and sputter again in ten seconds or so. Hope this makes some sense to someone. Your input is appreciated!
Eldon (WA)
04-17-2004 18:51:34
 Re: D14 Throttle Problem in reply to Mark G, 04-17-2004 12:05:50
I'd try turning out the power jet 1/2 turn at a time and see if that helps.....will it come out of it with partial choke? Sounds like it might be running a little lean.
Mark G
04-18-2004 15:21:59
 Re: Re: D14 Throttle Problem in reply to Eldon (WA), 04-17-2004 18:51:34
Yes, the choke seemed to do the trick. Of course now the RPM's run away so it looks like I have some other adjustments to make. When I turn the power jet out she immediately wants to die. Guess I'll go through the manual one more time and try to start from scratch. Any words of wisdom?
Mark G
04-17-2004 19:20:29
I'll try the choke tomorrow and let you know what happens. Thanks.
