stuck rings solution
Patrick
04-16-2004 14:36:16
I have an Allis Chalmers WD which I bought last year. Due to excessive oil; consumption and smoking I suspected stuck rings. After trying Marvel Mystery oil with no sucess I discovered Seafoam Super Creap spray. I ran the engine until medium warm and while runing at half speed I sprayed some into the carb then I shut her off pulled all 4 plugs and sprayed the remainder of the can into the 4 spark plug holes. After 2 hours Cranked her up and after some smoking the oil consumption was reduced by at least 75%. Hope this info helps someone with the same problem.
