Folks, thank you. The saga of the "doesn't want to run, oil out the exhaust, broken exhaust manifold studs, shifter stuck in first, dies when I push in on the choke" tractor seems to be nearing an end. I decided to move the last round hay bale out to the animals yesterday and tried the WD45. It started right up, as it warmed up I pushed in on the choke and it ran great... drove it over to the pasture where the hay is stored (all this time my wife's eyes are wide because a month ago it wouldn't run for more than a minute)... speared the hay bale and picked it up, drove it to the pasture and dropped it, parked the tractor and turned it off. No oil out the exhaust, no dying when the choke pushed in, a nice gray smoke and good power. Thanks to you folks. Now I'm going to work on the wiring. I think the only wires left intact are the ones to the ignition. There are no lights on it, and many cut wires sticking out of the harness. A few days ago there was a discussion about emailing the wiring diagram - if someone has one and could email it to [email protected] it would be greatly appreciated. Thanks again for all your help. The tractor's running great and the Mrs. thinks I'm turning in to a 'real' farmer. vic
