help identify
gregPA
04-14-2004 10:40:34
hello all, when i picked up my B in the fall i also picked up cultivator and other assorted parts that went with the tractor deal. the item in question is a front B rim on a 5 lug hub. the hub has a number on it but its probably a casting #610341 it has straight roller bearings inside the hub. the axel has 5/8 18 threads on both ends. 2 large cup washers and 2 smaller flat washers nuts on both ends. axel sticks out appx. 1 inch on either side rim is 15" would this have been some setup for an implement? thanks, greg
CHALMERSBOB
04-14-2004 14:12:43
 Re: help identify in reply to gregPA, 04-14-2004 10:40:34
HI GREG
SOUNDS LIKE IT MAY HAVE COME OFF A COMBINE OR BALER. THERE ARE OTHER POSSIBILLTIES ALSO. BOB
gregPA
04-14-2004 19:01:24
 Re: Re: help identify in reply to CHALMERSBOB, 04-14-2004 14:12:43
hi Bob. it seems that it would need to mount in a fork type mounting. reason i say that is the threads on both ends of the axel.anyway i blasted it and got the bearings loose. greg
CHALMERSBOB
04-15-2004 18:05:22
 Re: Re: Re: help identify in reply to gregPA, 04-14-2004 19:01:24
GREG, OK. I GUESS I DIDN'T QUITE UNDERSTAND WHAT YOU SAID YOU HAD. MOUNTS BETWEEN 2 SOMETHINGS
VERY INTERESTING. I'LL HAVE TO THINK ABOUT THAT. BOB
