Carb settings
Bud S.
04-13-2004 09:24:10
I have a 1957 D-17.We rebuilt the carb.The thing runs but black smoke comes out.I know that means it running rich but how do I set it ,it idles fine but when working or under load the smoke comes.And when off if gas isn't shut off,,, gas runs out,I set float level according to specks so now what?I am a beginner...Carb is zenith#229342 and under that #12217..I can use any help.BUD S
Dick L
04-13-2004 10:09:45
 Re: Carb settings in reply to Bud S., 04-13-2004 09:24:10
You probly have the float set okay. It is most likely the float valve is not seating properly. I have had at least four of the valves in the last three/four years with the rubber tips that would not seat no mater what I did to try to make it seat and shut off. I have put them in a pan of hot water on the stove and let it boil and droped it into the seat and put a clamp on it till it cooled and it still would leak. Most work fine but not all.
