more power
Steve
04-12-2004 20:31:20
i was wondering if anyone knew a trick or two on how to get more power out of a D21 turbo charged engine
Larry W.
04-12-2004 20:38:39
 Re: more power in reply to Steve, 04-12-2004 20:31:20
Well, first off, how much do you want to spend? How much do you want to do? Keep it for farming, or just pulling? Easy power, get a good used Roosa with the 450 head that has been worked over by a pump shop, put at least a 3lm charger on the top of her, advance the timing about 5 degrees, let the rpms run! Like I said, depends what you want to do??
steve
04-12-2004 20:54:07
 Re: Re: more power in reply to Larry W., 04-12-2004 20:38:39
i want to pull with it, the only restriction is Stock RPM, and Stock appearing fuel pump, thanks for the advice.
